Подделки (fake) из Гонконга
На сайте фирмы Кимбер в блоге наткнулся на предупреждение о фальшивых кабелях из китая.
http://www.kimber.com/blog/?cat=6
мне самому давали слушать Тара лабс Вектор 2 купленный в азии на ебее-очень подозрительные,внутри белой сетки проводки похожие на кимбер 8тс и звучали плохо,без баса сухо и не выразительно,вопрос кто нибудь сталкивался с такими проводами,я еще видел ,что продают и серебряные аудионотовские провода ?
Тоже самое на Аудиоквест сайте
http://www.audioquest.com/beware-of-counterfeits/
http://reviews.ebay.com/Fake-Audioquest-Speaker-Cable-amp-RCA-Interconnect?ugid=10000000018296741
Старика Ван ден Хуля обидели тоже.дает список жуликов
http://www.vandenhul.com/
  • WARNING - FAKE PRODUCTS ARE BEING OFFERED! There are currently quite a few offerings of fake copies of our cables (more specific The D-102 III Hybrid, The INTEGRATION Hybrid and The MAGNUM Hybrid) on various Ebay websites.Most of the people who offer these products are living in (the vicinity of) HongKong. The products are always offered without the original box and are mostly packed in a black bag with our copied logo on it. The inside of the cable is of very low quality and quite often completely different from the original. Buying such a cable is at your own risk and basically illegal. It will for sure ruin the quality of your installation. Please also be aware that an offer that is too good to be true most of the time is exactly that: too good to be true. Our products are realistically priced and a 50% discount is simply not possible. The following is a (not complete) list of Ebay-traders that are known to offer fake products:
There is also a regular offering of 50 cm van den Hul D-102 III Hybrid interconnect on Ebay by the seller sammybelamy. Please be aware that the cable is NOT factory terminated and does not have van den Hul RCA plugs on them. For this reason they are not an original van den Hul product, are not supported by us and don’t fall under our warranty program.
245300c.hk Kowloon Hong Kong apple1917 Hong Kong Hong Kong audiophile_king Sha Tin Hong Kong buyeasy88 Tai Po Hong Kong charming_audio Taipo Hong Kong currygipson Hong Kong Hong Kong curtisobrian Hong Kong Hong Kong dream_mart Hong Kong Hong Kong easybuy_mart Sheung Shui Hong Kong fantastic_audio Tuan Wan Hong Kong greataudio_store Tuen Mun Hong Kong hi_amp9 Hong Kong Hong Kong highendgear-box Hong Kong Hong Kong hongkongsupply Hong Kong Hong Kong ibidmart Hong Kong Hong Kong janeh2100 Hong Kong Hong Kong jewelmart_hk Hong Kong Hong Kong jp_hobby_jp Fotan Hong Kong lil_doraemon Hong Kong Hong Kong lotsa_lotsastore Hong Kong Hong Kong on9cowcow Hong Kong Hong Kong Toolworldstore Hong Kong Hong Kong trade-bid-bid Hong Kong Hong Kong
А может просто сам новый (бело рыжий) в отличии от старого сине черного так звучит?
И Кимбер говорит что подделка, я сам брал у оф дилера демо кабель старый потом мне сделали точно такой же из новой версии, я конечно ещё послушаю его , но чувствую что сине черный звучит лучше.
Не могу точно сказать,я читаю западные форумы и все воют в один голос,что все завалено подделками,Кардас тоже левый весь,народ стал путаться какой левый какой правый,пипец ,
Стоит тогда присмотреться к кабелям отечественных производителей - их не подделывают default_smile.png
Вот это и смущает, что то подозрительно слишком много подделок, а звук у нового и правда ярковато суховатый с небольшим провальчиком на басе , Прогрев конечно несколько исправляет ситуацию, но со старым всё равно не сравнить. Или что офдилер подделками торгует?
Товарищи американцы утверждают,что дилеры не торгуют их продукцией на ебее и аудиогоне,если типа покупаете на вторичном рынке требуйте чек от дилера и дают список дилеров
http://www.kimber.com/wheretobuy/international/
Ну да у них и покупал.
Походил по ссылкам на ебей - Я в шоке, точно такие кимберовские лопатки и термо трубки только цена не 100 долларов …
Самое печальное,что фирмам производителям похоже глубоко наплевать,покупайте у дилеров и все ,кимбер ладно а как аудиоквест с коробочками , там вообще засада ,у японского дилера аж на первой странице ахтунг горит, про иммитации
http://dm-importaudio.jp/audioquest/
Ну так чего Вы разволновались? Покупайте у офдилеров и все.
Они наоборот заинтересованы: чем больше подделок, тем охотнее будут брать в магазине. С вторички фирмы доход не получают. А раз подделывают, то кабель действительно хорош.
Советую зайти к оф.дилеру и показать коробку от шнуров аудиоквест и надписи, что сделано в сша вы не найдете,так где они изготавливаются?
+1
Не понял. Я лучше “зайду” к офдилеру и куплю у него то, что мне нужно. Например, кабель. А показывать я ему ничего не буду default_smile.png.
Интересно http://www.ebay.com/itm/Oyaide-Tunami-II-SP-Y-Speaker-Cable-Tunami-Nigo-SPSL-/360482807983?pt=LH_DefaultDomain_0&hash=item53ee7320af это тоже изделия китайских умельцев?
На ebay изделий OYAIDE развелось и продавцы как на подбор
Кстати про дилеров. В Аудиогалерее видел на витрине подделки под Ояйдовские разъемы. И стоят они на одной полке с настоящими, только ассортимент был у фейков чуть побольше. Правда надо признать, что продавцы не утверждают, что это Ояйде и говорят, что некоторым покупателям все равно какие брать. Во как! Один только вопрос, откуда эти разъемы там? Это же магазин Эзотерики? Или?
Кимбер левый даже по фото в первом посте узнаваем.А взяв в руки невозможно не узнать,просто надо интересоваться как настоящий выглядит
