А лучше конечно услышать этих малышей все же в живую
… в галерее Назаров например . Сравнить с полноразмерной акустикой и удивится ![]()
Вот и этим малышам достался кусочек славы) , признание и награда от авторитетного издания Stereo Times pf 2015 год …
… Wavetouch Grand Teton SE ($3,495.00/pair): These highly efficient (94dB/watt) monitor speakers have been improved in the SE version. They have a slightly taller cabinet than the original GT, which houses a premium-quality crossover using Mundorf capacitors, Nordost internal wiring, and Jensen foil inductors. They provide superb frequency balance and expansive precise imaging with a very good sense of dynamics to boot. And they play quite well with my 300B mono amps. (Frank Alles) …
Grand Teton buyer feedback
Just hooked up my Grand Teton speakers. Awesome!!!
Room filling sound in a 25’ X 20’ Room! Not just “room filling” sound but Very very detailed and more Dynamic than most larger speakers. Very detailed midrange and very good bass extension, rated down to 40hz at first I didn’t believe this bookshelf speaker could deliver quality bass that low but after 10 minutes and a couple of drum test records boy I was proven wrong.
I have had Magnepans and Martin Logans and in many ways the Grand Teton’s are more detailed and transparent and Definitely more dynamic. I love them, a very natural speaker to listen to and the sound stage is way BIGGER than you would think from any bookshelf speaker this size or even the Wilson Watt Puppy’s , yes that big , don’t believe me find somewhere to listen to them. In a big room you will need 15 watts or more. I have run tube and solid state, both have there good points.
Вчера решил попробовать новые ламповые маломощные однотакты на лампах VT-52 прямонакальный триод и 247й , прямонакальным пентодом , в паре с акустикой Grand Teton … и каково было мое удивление ! ![]()
Я почему то думал что придется ручку громкости откручивать по максимуму , что бы хоть что то услышать , так как сам производитель рекомендовал к ним усиление в классе А/АВ как минимум помощнее. А тут и 3 х Вт нету . Но это не беда , как оказалось с ручкой громкости на 12 часов производительности этих усилителей было более чем достаточно для комнаты 14-22 кв м. Эти маленькие , чуть ли не настольные (хотел сказать карманные) усилители ввергли меня в шок . Это лучшее сочетание / связка акустики GT и усиления за все время моего знакомства с ними. Мало того что естественность происходящего , атмосфера записи , натуральность поселились у вас в комнате , так то количество баса , которое генерирует эти полочники , просто за гранью разумного . Акустика растворяется в пространстве и ты погружаясь в то самое пространство и действо начинаешь не вольно искать , а где же спрятан саб , и как все удачно сшито .
Вот так волею судеб опять возвращаешься к лампе . И понятно что на рынке куча подобного рода изделий от китайского ширпотреба , до авторских и фирменных работ , но именно грамотно сделанных усилителей , с душой и качественным подбором комплектующих ( даже среди фирменных , брендовых изделий) находятся единицы . И это те алмазы и алмазики которые не требуют уже огранки и подбора , включаешь и получаешь истинное удовольствие и наслаждение .
PS … источником служил iPod 5G (wolfson WM8758) … то ли будет с более аудиофильским источником
Вот описание одного из этих малышей …
… “Авторский ламповый усилитель, построенный по однотактной схеме без обратных связей Aikido Джона Броски (Single-End) в классе «А». Выходная мощность – 2,7 Вт на нагрузке 8 Ом. В выходном каскаде применены раритетные пентоды прямого накала TYPE PZ 247 GLOBE американского производства компании CECO, на бакелитовых юбках надписи выполнены гравировкой. Ультралинейная схема включения выходного трансформатора. Выходные трансформаторы http://www.ebay.com/itm/221258641477. Драйверный каскад построен на двойных триодах 12SL7GTB и 12SN7GTB компании GE (General Electric) середины 80х годов. Лампы NOS (новые, из прежних запасов) - имеют эксклюзивный конструктив: октальный цоколь с монетным дном.
Айкидо является одним из лучших ламповых усилителей, он позволит Вам услышать то, что вы не слышали раньше! Это лучшее схемное решение с точки зрения шумов и музыкальности, вы не поверите своим ушам… Звук можно охарактеризовать как открытый и легкий, с невероятной детализацией и разрешением. Я использовал с различной акустикой ,от открытых щитов до классических ящиков , наконец он позволил мне услышать подробности, недостижимые другими усилителями.
Применены только качественные компоненты! В сигнальных цепях применены углепластиковые малошумящие HI-END резисторы «Allen&Bradley» . Межкаскадные конденсаторы - полиэтилентерефталатные металлопленочные К73-16. http://kuzcon.ru/uploads/files/datasheet_k73-16.pdf На каждом конденсаторе имеется отметка ОТК (отдел технического контроля, подтверждающая высокое качество изделия, соответствующее требованиям государственного стандарта) Силовой трансформатор выполнен на заказ на тороидальном сердечнике в заводских условиях по самым жестким требованиям Государственного Стандарта. Межслойная изоляция – тонкий электротехнический картон, обмоточный провод распаян на лепестки, готовое изделие обмотано льняной лентой и пропитано в лаке. В усилителе применена схема стабилизации анодного напряжения на полевых транзисторах с изолированным затвором , с плавным нарастанием значения питающего напряжения для каждого отдельного канала. Так же применены стабилизаторы фиксированного смещения для каждой из выходных ламп. Правильно выбранный режим работы гарантирует «долгую жизнь» выходных пентодов и превосходное звучание! Схема реализова печатным монтажом! ПОЛНОЕ ОТСУТСТВИЕ МИКРОФОННОГО ЭФФЕКТА! Значение фона на выходе порядка 4-9 мВ. Медные проводники облужены и все пайки выполнены бессвинцовым припоем с содержанием серебра Ag +3,5%, проводники от входных разъемов до регулятора громкости выполнены посеребрённым коаксиальным тефлоновым кабелем РК-50-3-23. Регулятор громкости – ALPS, производства Япония. Корпус изготовлен из анодированного алюминиевого профиля. Позолоченные входные разъемы RCA и клеммы для подключения акустических систем”.
Все это надо услышать , что бы поверить в то что это реально одно из лучших творений ламповой техники.
… и описание второго , на триодах.
Предлагаю авторский ламповый усилитель, построенный по однотактной схеме без обратных связей (Single-End) в классе «А». Выходная мощность – 2,86 Вт на нагрузке 8 Ом. В выходном каскаде применены раритетные триоды прямого накала TYPE VT-52 (special type45 или 2A3 monoplate с 6 ти вольтовым напряжением накала) выпущенные для армии США, производства компании SENCO (SYLVANIA). Выходные трансформаторы http://www.ebay.com/itm/221258641477. Все примененные лампы NOS (новые из прежних запасов) Драйверный каскад построен на раритетном пентоде VT-269 (type 717 ) 40-х годов компании RAYTHEON нагруженный на катодный повторитель Джона Броски на лампе 6SN7GTB компании GE (General Electric) середины 60х годов.
Применены только качественные компоненты! В сигнальных цепях применены углепластиковые малошумящие HI-END резисторы «Allen&Bradley» с классом точности 5 %. Межкаскадные конденсаторы - полиэтилентерефталатные металлопленочные К73-16. http://kuzcon.ru/uploads/files/datasheet_k73-16.pdf На каждом конденсаторе имеется отметка ОТК Силовой трансформатор выполнен на заказ на тороидальном сердечнике в заводских условиях по самым жестким требованиям ГОСТа. Межслойная изоляция – тонкий электротехнический картон, обмоточный провод распаян на лепестки, готовое изделие обмотано льняной лентой и пропитано в лаке. В усилителе применена схема стабилизации анодного напряжения на полевых транзисторах с изолированным затвором, с плавным нарастанием значения питающего напряжения для каждого отдельного канала. Так же применены стабилизаторы фиксированного смещения для каждой из выходных ламп. Правильно выбранный режим работы гарантирует «долгую жизнь» выходных триодов и превосходное звучание! Схема реализована печатным монтажом! ПОЛНОЕ ОТСУТСТВИЕ МИКРОФОННОГО ЭФФЕКТА! Значение фона на выходе порядка 4-9 мВ. Медные проводники облужены и все пайки выполнены бессвинцовым припоем с содержанием серебра Ag +3,5%, проводники от входных разъемов до регулятора громкости выполнены посеребрённым коаксиальным тефлоновым кабелем РК-50-3-23. Регулятор громкости – ALPS RK27 «Blue Velvet», производства Япония. Корпус изготовлен из анодированного алюминиевого профиля. Позолоченные входные разъемы RCA и клеммы для подключения акустических систем."
Второй ( на VT-52 ) дает больше баса , но он чуточку менее собран , и в каких то жанрах усилитель на пентоде с более выраженной серединой будет выглядеть предпочтительней.
Новые модели … ![]()
